  • 跟教程在Edge Impulse上训练的模型运行报错
    • 固件信息:
      报错信息:
      代码:
      #Edge Impulse - OpenMV Image Classification Example
      net = None
      labels = None
      except Exception as e:
      print(e)
      print(clock.fps(), "fps")
      Edge Impulse训练信息:
    • 你用的是OpenMV4 H7,不能运行edge impulse上的分类模型,OpenMV4 H7 Plus可以用。
      建议用星瞳AI云服务,可以支持OpenMV4 H7
    • @kidswong999 我这个PLUS也有这个问题啊
    • 我这个新买的Plus也有这个问题,已经把MobileNet设置到资源最小了也不行
    • 版本问题,4.6.0也会出现,回退版本4.5.4就可以了
    • 新的固件,使用下面新的代码:
      import sensor
      import ml
      from ml.utils import NMS
      import math
      import image
      min_confidence = 0.4
      print(model)
      model = ml.Model("trained.tflite", load_to_fb=True)
      colors = [  # Add more colors if you are detecting more than 7 types of classes at once.
          (255, 0, 0),
          (0, 255, 0),
          (255, 255, 0),
          (0, 0, 255),
          (255, 0, 255),
          (0, 255, 255),
          (255, 255, 255),
      # FOMO outputs an image per class where each pixel in the image is the centroid of the trained
      # object. So, we will get those output images and then run find_blobs() on them to extract the
      # centroids. We will also run get_stats() on the detected blobs to determine their score.
      # The Non-Max-Supression (NMS) object then filters out overlapping detections and maps their
      # position in the output image back to the original input image. The function then returns a
      # list per class which each contain a list of (rect, score) tuples representing the detected
      # objects.
          n, oh, ow, oc = model.output_shape[0]
          nms = NMS(ow, oh, inputs[0].roi)
          for i in range(oc):
              blobs = img.find_blobs(
                  threshold_list, x_stride=1, area_threshold=1, pixels_threshold=1
              for b in blobs:
                  rect = b.rect()
                  x, y, w, h = rect
                  score = (
                  nms.add_bounding_box(x, y, x + w, y + h, score, i)
          return nms.get_bounding_boxes()
          for i, detection_list in enumerate(model.predict([img], callback=fomo_post_process)):
              if i == 0:
                  continue  # background class
              if len(detection_list) == 0:
                  continue  # no detections for this class?
              for (x, y, w, h), score in detection_list:
                  print(f"x {center_x}\ty {center_y}\tscore {score}")
          print(clock.fps(), "fps", end="\n")
