# Template Matching Example - Normalized Cross Correlation (NCC)
# image patches to parts of an image... expect for extremely controlled environments
# NCC is not all to useful.
# a lot of work to be made into somethin useful. This script will remain to show
import sensor
import image
from image import SEARCH_EX
# from image import SEARCH_DS
# Reset sensor
sensor.reset()#摄像头重置
# Set sensor settings
sensor.set_contrast(1)#设置对比度
sensor.set_gainceiling(16)#自动增益
sensor.set_framesize(sensor.QQVGA)#分辨率大小,最大支持QQVGA
# sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
sensor.set_pixformat(sensor.GRAYSCALE)#灰度
# Load template.
#template1 = image.Image("/1.pgm")#模板图片pgm格式
template2 = image.Image("/2.pgm")#模板图片pgm格式
template3 = image.Image("/3.pgm")#模板图片pgm格式
# Run template matching
r1 = img.find_template(#调用模板匹配函数
template1, 0.70, step=4, search=SEARCH_EX
) # , roi=(10, 0, 60, 60))#template图片,0.7匹配阈值,roi设置了是在规定区域寻找图像,不设置了默认整个区域寻找
if r1:#如果找到模板图片
img.draw_rectangle(r1,color=(0,0,0))
r2 = img.find_template(#调用模板匹配函数
template2, 0.70, step=4, search=SEARCH_EX
if r2:#如果找到模板图片
img.draw_rectangle(r2,color=(255,0,0))
r3 = img.find_template(#调用模板匹配函数
template3, 0.70, step=4, search=SEARCH_EX
if r3:#如果找到模板图片
img.draw_rectangle(r3,color=(0,0,0))
