  • 用该代码,2代表2,3代表1,但是方框只会显示一个颜色,而且无论什么数字都能被方框罩住
    • # Template Matching Example - Normalized Cross Correlation (NCC)
      # image patches to parts of an image... expect for extremely controlled environments
      # NCC is not all to useful.
      # a lot of work to be made into somethin useful. This script will remain to show
      import sensor
      import image
      from image import SEARCH_EX
      # from image import SEARCH_DS
      # Reset sensor
      sensor.reset()#摄像头重置
      # Set sensor settings
      sensor.set_contrast(1)#设置对比度
      sensor.set_gainceiling(16)#自动增益
      sensor.set_framesize(sensor.QQVGA)#分辨率大小,最大支持QQVGA
      # sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      sensor.set_pixformat(sensor.GRAYSCALE)#灰度
      # Load template.
      #template1 = image.Image("/1.pgm")#模板图片pgm格式
      template2 = image.Image("/2.pgm")#模板图片pgm格式
      template3 = image.Image("/3.pgm")#模板图片pgm格式
      # Run template matching
          r1 = img.find_template(#调用模板匹配函数![1_1722223662403_8f4de3c4653a29c6a9df40b2281ef50.jpg](https://fcdn.singtown.com/92922a81-8e2d-4111-ae6e-6fefb02ad501.jpg) ![0_1722223662402_288e461d9390ea8d52ccbd8164ab3e0.jpg](https://fcdn.singtown.com/e7a5c6e7-7e3c-40eb-9e85-f0e2ec517e66.jpg)
              template1, 0.70, step=4, search=SEARCH_EX
          )  # , roi=(10, 0, 60, 60))#template图片,0.7匹配阈值,roi设置了是在规定区域寻找图像,不设置了默认整个区域寻找
          if r1:#如果找到模板图片
              img.draw_rectangle(r1,color=(0,0,0))
          r2 = img.find_template(#调用模板匹配函数
              template2, 0.70, step=4, search=SEARCH_EX
          if r2:#如果找到模板图片
              img.draw_rectangle(r2,color=(255,0,0))
          r3 = img.find_template(#调用模板匹配函数
              template3, 0.70, step=4, search=SEARCH_EX
          if r3:#如果找到模板图片
              img.draw_rectangle(r3,color=(0,0,0))
