AttributeError: 'module' object has no attribute 'classify"
用星瞳ai训练的模型用h7plus报这个错误要怎么解决呢
This code run in OpenMV4 H7 Plus
sensor.skip_frames(time=2000) # Let the camera adjust.labels = [line.rstrip() for line in open("labels.txt")]
class_num = len(labels)clock = time.clock()
for obj in tf.classify("trained.tflite", img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
output = obj.output()
for i in range(class_num):
print("%s = %f" % (labels[i], output[i]))
print(clock.fps(), "fps")
用4.5.5的固件。
