  • 使用Mnist数字识别的时候报错为‘module' object has no attribute 'classify'
    • import sensor, image, time, os, tf
      img = sensor.snapshot().binary([(0,64)])
      for obj in tf.classify("trained.tflite", img, min_scale=1.0, scale_mul=0.5, x_overlap=0.0, y_overlap=0.0):
      output = obj.output()
      number = output.index(max(output))
      print(number)
      print(clock.fps(), "fps")
    • 将openmv的固件版本按照https://singtown.com/learn/50903/的办法降级成v4.5.5即以前的版本即可
    • 但是我现在用的就是v4.2.0,还是有这个问题要怎么办
    • 更新为v4.5.5的固件
