  • 为什么在网站上训练出来的模型运行会报错呀
    • 0_1722156834655_微信截图_20240728165325.png 为什么在网站上训练出来的模型运行会报错呀
      net = None
      labels = None
      min_confidence = 0.5
          net = tf.load("trained.tflite", load_to_fb=uos.stat('tr.ained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • OpenMV H7上不能运行edge impulse训练的模型,可以用星瞳AI云服务训练。
      https://docs.singtown.com/ai/zh/latest/toturial/classify.html
