  • 识别到的数据最后两个有问题一直是0,串口发不出数据不知为什么,上位机和主控都收不到
      import ustruct
      import display
      from pyb import UART,LED
      #****************************阈值调整*******************************
      area=(45, 2, 200, 198)
      red=(88, 100, -16, 22, -128, 127)  #only red
      sensor.set_auto_whitebal(True)
      sensor.set_auto_gain(False)
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      lcd = display.SPIDisplay()
      #****************************曝光时间*******************************
      #sensor.set_auto_exposure(False,4500)
      #*****************************line_threshold**********************
      line_threshold=2500
      rect_threshold=10000
      uart = UART(3,115200)
      def calculate_intersection(line1, line2):
          计算两条线的交点
          a1 = line1.y2() - line1.y1()
          b1 = line1.x1() - line1.x2()
          c1 = line1.x2()*line1.y1() - line1.x1()*line1.y2()
          a2 = line2.y2() - line2.y1()
          b2 = line2.x1() - line2.x2()
          c2 = line2.x2() * line2.y1() - line2.x1()*line2.y2()
          if (a1 * b2 - a2 * b1) != 0 and (a2 * b1 - a1 * b2) != 0:
              cross_x = int((b1*c2-b2*c1)/(a1*b2-a2*b1))
              cross_y = int((c1*a2-c2*a1)/(a1*b2-a2*b1))
              return (cross_x, cross_y)
          return None
      def sending_data(rx,ry,cx,c):
          global uart;
          data = ustruct.pack("<bhhhhhhhhb",
                              0xFF,
                              int(rx),
                              int(ry),
                              int(cx),
                              int(cy),
                              int(cw),
                              int(ch),
                              int(xx),
                              int(xy),
                              int(xw),
                              int(xh),
                              0xFE)
          uart.write(data);
      cx=0
      cy=0
      rx=0
      ry=0
      a=[0,0,0,0,0,0,0,0,0,0]
         # lcd.write(sensor.snapshot())  # 拍照并显示图像。
          img = sensor.snapshot().lens_corr(strength = 1.6, zoom = 1.0)
          red_point= img.find_blobs([red])
          if red_point:
              r= red_point[0]
              img.draw_rectangle(r[0:4],color=(0,0,0)) # rect
              rx=r[5]
              ry=r[6]
              #print(rx,ry)
      #******************************************************************lines*****************
          lines = img.find_lines(roi=area, threshold=line_threshold)
          i=0
          if len(lines)==4 :
              theta0=lines[0].theta()
              theta1=lines[1].theta()
              theta2=lines[2].theta()
              theta3=lines[3].theta()
              for line in lines:
                  img.draw_line(line.line(),color=[255,0,0])
              if abs(theta0-theta1)>45:
                  a[i]=calculate_intersection(lines[0],lines[1])[0]
                  i=i+1
                  a[i]=calculate_intersection(lines[0],lines[1])[1]
                  i=i+1
              if abs(theta0-theta2)>45:
                  a[i]=calculate_intersection(lines[0],lines[2])[0]
                  i=i+1
                  a[i]=calculate_intersection(lines[0],lines[2])[1]
                  i=i+1
              if abs(theta0-theta3)>45:
                  a[i]=calculate_intersection(lines[0],lines[3])[0]
                  i=i+1
                  a[i]=calculate_intersection(lines[0],lines[3])[1]
                  i=i+1
              if abs(theta1-theta2)>45:
                  a[i]=calculate_intersection(lines[2],lines[1])[0]
                  i=i+1
                  a[i]=calculate_intersection(lines[2],lines[1])[1]
                  i=i+1
              if abs(theta1-theta3)>45:
                  a[i]=calculate_intersection(lines[1],lines[3])[0]
                  i=i+1
                  a[i]=calculate_intersection(lines[1],lines[3])[1]
                  i=i+1
              if abs(theta3-theta2)>45:
                  a[i]=calculate_intersection(lines[2],lines[3])[0]
                  i=i+1
                  a[i]=calculate_intersection(lines[2],lines[3])[1]
                  i=i+1
              print(a)
              FH = bytearray([0xFF,rx,ry,a[0],a[1],a[2],a[3],a[4],a[5],a[6],a[7],0xFE])
              uart.write(FH)
              #print(rx,ry)
    • 先用示波器看串口有没有数据。
