  • 代码倒数第四行,运行后说是没有定义,问一下在哪里定义?
    • #Single Color RGB565 Blob Tracking Example
      #This example shows off single color RGB565 tracking using the OpenMv Cam.
      #Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max,)
      #The below thresholds track in general red/green/blue things. You may wish to tune them..
      thresholds = (30,100,15,127,15,127) # generic_red_thresholds
      #Only = blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" area
      # returned by "find_blobs"below. Change "pixels_threshold" and "area_threshold" if you change the
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold = 200,area_threshold = 200, merge=True):
              img.draw_cross(blob.cx(),blob.cy())
    • for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold = 200,area_threshold = 200, merge=True):
      改为
      for blob in img.find_blobs([thresholds], pixels_threshold = 200,area_threshold = 200, merge=True):
