  • openmv判断两直线是否相交
    • #通过检测两直线是否相交判断十字路口
      line_threshold = (30, 100)
      noc = 0   #number of crossroad
          img = sensor.snapshot().binary([line_threshold])
          # 检测直线
          lines = img.find_lines(threshold = 1000, theta_margin = 25, rho_margin = 25)
          for line in lines:
              img.draw_line(line.line(), color=127)
          # 检测十字
          cross_detected = False
          for i in range(len(lines)):
              for j in range(i+1, len(lines)):
                  if abs(lines[i].theta() - lines[j].theta()) < 30:
                      continue
                  intersection = lines[i].intersection(lines[j])
                  if intersection:
                      x, y = int(intersection.x()), int(intersection.y())
                      img.draw_cross(x, y)
                      cross_detected = True
                      noc = noc+1
          # 输出是否检测到十字
          print("Cross detected: ", cross_detected)
          print(noc)
      提示AttributeError: ‘line’ object has no attribute ‘intersection’
      光标位置intersection = lines[i].intersection(lines[j])
      openmv里有没有类似intersection()获取交叉点的方法呢
    • 目前没有这个函数,需要自己计算。
