  • openmv进行十字路口检测,判断两直线是否相交
    • 为什么会提示TypeError: object ‘int’ isn’t a tuple or list
      提示错误的时候光标定位在img = sensor.snapshot().binary(line_threshold)
      import sensor, image
      # 初始化摄像头
      line_threshold = (30, 100)
          # 检测直线
          lines = img.find_lines(threshold = 1000, theta_margin = 25, rho_margin = 25)
          for line in lines:
              img.draw_line(line.line(), color=127)
          # 检测十字
          cross_detected = False
          for i in range(len(lines)):
              for j in range(i+1, len(lines)):
                  if abs(lines[i].theta() - lines[j].theta()) < 30:
                      continue
                  intersection = lines[i].intersection(lines[j])
                  if intersection:
                      x, y = int(intersection.x()), int(intersection.y())
                      img.draw_cross(x, y)
                      cross_detected = True
          # 输出是否检测到十字
          print("Cross detected: ", cross_detected)
    • 准确的说光标定位在img = sensor.snapshot().binary(line_threshold)的后面
    • 12行,改为:img = sensor.snapshot().binary([line_threshold])
