  • 使用SD卡报错MemoryError: memory allocation failed
      from image import SEARCH_EX
      usart3 = UART(3, 115200)
      usart3.init(115200, bits=8, parity=None, stop=1)
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.skip_frames(time=2000)
      print("硬件初始化完毕")
      # 引入模板图片的路径
      templates1 = ["/01.1.pgm", "/01.2.pgm", "/01.3.pgm", "/01.4.pgm", "/01.5.pgm"]
      templates2 = ["/02.1.pgm", "/02.2.pgm", "/02.3.pgm", "/02.4.pgm", "/02.5.pgm"]
      # 将图片路径列表置换为图片列表
      for i in range(len(templates1)):
          templates1[i] = image.Image(templates1[i])
      for i in range(len(templates2)):
          templates2[i] = image.Image(templates2[i])
      # 循迹红色色块阈值
      red = [24, 69, 0, 43, 7, 33]
      # 循迹识别区块
      areas = [(44, 56, 14, 8), (58, 56, 14, 8), (72, 56, 14, 8), (86, 56, 14, 8), (100, 56, 14, 8)]
      # 数字识别标志
      recognized_num = None
      last_recognized_num = 0
      # 得到循迹值函数
      def getTrace(img):
          Trace = [0, 0, 0, 0, 0]
          for area in areas:
              statistics = img.get_statistics(roi=area)
              if red[0] < statistics.l_mean() < red[1] and red[2] < statistics.a_mean() < red[3] and red[4] < statistics.b_mean() < red[5]:
                  Trace[areas.index(area)] = 1
          return Trace
      # 标记函数
      def Mark(img, Trace):
          for i in range(len(Trace)):
              area = areas[i]
              img.draw_rectangle(area)
              if Trace[i] == 1:
                  img.draw_string(area[0] + 4, area[1], "1")
                  img.draw_string(area[0] + 4, area[1], "0")
      # 串口发送数据函数
      def usart_send(Trace, recognized_num):
          Trace_num = 0
          if Trace:
              Trace_num = Trace[4] * 1 + Trace[3] * 2 + Trace[2] * 4 + Trace[1] * 8 + Trace[0] * 16
          data = bytearray([0xa3, 0xb3, Trace_num, recognized_num, 0xc3])
          usart3.write(data)
          print("Data sent:", [hex(b) for b in data])  # 打印发送的数据以调试
      # 终端打印函数
      def Print(Trace, recognized_num):
          print("Trace=", Trace, "Recognized Num=", recognized_num)
      # 找数字函数:(返回数字的外框)
      def findNum(img, templates):
          img_gray = img.to_grayscale()
          best_score = 0.0
          best_rect = None
          for t in templates:
              result = img_gray.find_template(t, 0.4, step=4, search=SEARCH_EX)
              if result is not None:
                  print(f"Found template {t} at {result}")
                  if best_rect is None or result[1] > best_score:
                      best_score = result[1]
                      best_rect = result[0]
          return best_rect
      ###########################################  主函数  ################################################
      for i in range(50):
      data = bytearray([0x6B, 0x6B, 0x6B])
      usart3.write(data)
          if recognized_num is None:
              Rect2 = findNum(img, templates2)
              Rect1 = findNum(img, templates1)
              if Rect2 is not None:
                  recognized_num = 2
              elif Rect1 is not None:
                  recognized_num = 1
              if recognized_num is not None:
                  last_recognized_num = recognized_num
                  usart_send([], recognized_num=recognized_num)
                  print("Recognized num:", recognized_num)
          Trace = getTrace(img)
          Mark(img, Trace)
          usart_send(Trace, last_recognized_num)
          Print(Trace, last_recognized_num)
    • 你一开始把所有模板图片导入了,所以内存爆了。
      https://book.openmv.cc/image/mulity-template-match.html
