  • MemoryError: Out of fast frame buffer stack memory
      Edge Impulse - OpenMV Image Classification Example
      sensor.set_framesize(sensor.QQVGA) # Set frame size to QVGA (320x240)
      net = "trained.tflite"
      for obj in tf.classify(net,img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
      print(clock.fps(), "fps")
      OpenMv4 Cam H7 R2跑不了训练出来的模型吗
    • 可以使用星瞳AI云服务训练,生成OpenMV的分类模型。https://ai.singtown.com/zh-hans/
