  • 万用表测量openmv的gnd和 vcc与p5引脚直接连通
    • 万用表测量openmv的gnd和vcc直接连通,gnd和p5引脚直接连通,openmv的p5引脚我们代码里面配置的蓝牙串口的RX功能
      请在这里粘贴代码4# Edge Impulse - OpenMV Object Detection Exampleimport sensor, image, time, os, tf, math, uos, gc, pybfrom pyb import UART, Pin, LEDuart1 = UART(1, 9600)            # P0-Rx, P1-Tx----舵机控制uart3 = UART(3, 38400)           # P5-Rx, P4-Tx----蓝牙通讯# openmv 内置led灯red_led   = LED(1)green_led = LED(2)blue_led  = LED(3)#设置输入引脚,并开启上拉电阻, 控制按钮pin_7 = Pin('P7', Pin.IN, Pin.PULL_UP)        # 正转, 输出 0pin_8 = Pin('P8', Pin.IN, Pin.PULL_UP)        # 反转, 输出 1pin_9 = Pin('P9', Pin.IN, Pin.PULL_UP)        # 数字识别模式#p_in = Pin('P7', Pin.IN, Pin.PULL_UP)#设置p_in为输入引脚,并开启上拉电阻#value = p_in.value() # get value, 0 or 1#读入p_in引脚的值###############################################################################################################sensor.reset()                         # Reset and initialize the sensor.sensor.set_pixformat(sensor.RGB565)    # Set pixel format to RGB565 (or GRAYSCALE)sensor.set_framesize(sensor.QVGA)      # Set frame size to QVGA (320x240)sensor.set_windowing((240, 240))       # Set 240x240 window.sensor.skip_frames(time=2000)          # Let the camera adjust.sensor.set_hmirror(True)              #水平方向翻转sensor.set_vflip(True)                #垂直方向翻转net = Nonelabels = Nonemin_confidence = 0.5try:    # load the model, alloc the model file on the heap if we have at least 64K free after loading    net = tf.load("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))except Exception as e:    raise Exception('Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')try:    labels = [line.rstrip('\n') for line in open("labels.txt")]except Exception as e:    raise Exception('Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')colors = [ # Add more colors if you are detecting more than 7 types of classes at once.    (255,   0,   0),    (  0, 255,   0),    (255, 255,   0),    (  0,   0, 255),    (255,   0, 255),    (  0, 255, 255),    (255, 255, 255),    (128, 128,   0),    (128, 128, 128)]###############################################################################################################count_lists = [0, 0, 0, 0, 0, 0, 0, 0, 0]   # 记录每个数出现的次数shots_number = 0                            # shots_number 记录拍照的次数k = 1                                       # k 用于发送1次串口给舵机receive_sign = ['UU',0x05,0x08,0x00,0x01,0x00]clock = time.clock()while(True):    clock.tick()    value_7 = pin_7.value()    value_8 = pin_8.value()    value_9 = pin_9.value()    if (value_7 == 0):                    # 正转, 发送 0        red_led.on()        pyb.delay(1000)        red_led.off()        uart3.write("0")    elif(value_8 == 0):                    # 反转, 发送 1        green_led.on()        pyb.delay(1000)        green_led.off()        uart3.write("1")    elif(value_9 == 0):                    # 数字识别模式        blue_led.on()        pyb.delay(1000)        blue_led.off()        running = True        while(running):            img = sensor.snapshot()            shots_number = shots_number + 1            if(k==1):                         # k 值调整来控制舵机是否动                data = bytearray([0x55, 0x55, 0x05, 0x06, 0x00, 0x01, 0x00])  #驱动云台, 第0组动作,执行1次                uart1.write(data)                k=0            for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])):                if (i == 0): continue # background class                if (len(detection_list) == 0): continue                #取出识别数字                number = int(labels[i])                count_lists[number] = count_lists[number] + 1                if (shots_number%10 == 0):                    max_index = max(enumerate(count_lists), key=lambda x: x[1])[0]  # 取出出现概率最高的数                    print(max_index)                                                # max_index 为识别的数字                    print()                    count_lists = [0, 0, 0, 0, 0, 0, 0, 0, 0]                    if (max_index%2 == 1):                          # 奇数, 发送0, 正转                        uart3.write("0")                    if (max_index%2 == 0):                          # 偶数, 发送1, 反转                        uart3.write("1")                #画面圈出数字                for d in detection_list:                    [x, y, w, h] = d.rect()                    center_x = math.floor(x + (w / 2))                    center_y = math.floor(y + (h / 2))        #            print('x %d\ty %d' % (center_x, center_y))                    img.draw_circle((center_x, center_y, 12), color=colors[i], thickness=2)            if uart1.any():                a = uart1.read()                print(a)                if receive_sign == a:                       running = False            value_7 = pin_7.value()            if (value_7 == 0):                    # 点击P7,退出数字识别模式                blue_led.on()                pyb.delay(1000)                blue_led.off()                running = False                k=1        #    print(clock.fps(), "fps", end="\n\n")
    • 硬件坏了,寄回卖家维修。
