  • 为什么运行示例会这样?
    • 请在这里粘贴代码# This work is licensed under the MIT license.
      # Keypoints descriptor example.
      # This example shows how to save a keypoints descriptor to file. Show the camera an object
      # and then run the script. The script will extract and save a keypoints descriptor and the image.
      # You can use the keypoints_editor.py util to remove unwanted keypoints.
      import sensor
      import image
      # Reset sensor
      # Sensor settings
      sensor.set_contrast(3)
      sensor.skip_frames(time=2000)
      FILE_NAME = "desc"
      # NOTE: See the docs for other arguments
      kpts = img.find_keypoints(max_keypoints=150, threshold=10, scale_factor=1.2)
      if kpts is None:
          raise (Exception("Couldn't find any keypoints!"))
      image.save_descriptor(kpts, "/%s.orb" % (FILE_NAME))
      img.save("/%s.pgm" % (FILE_NAME))
      img.draw_keypoints(kpts)
      sensor.snapshot()
      time.sleep_ms(1000)
      raise (Exception("Please reset the camera to see the new file."))
      ![0_1715741831530_7c831c12-c730-4ff6-975e-01a0e5bc49f2-image.png](https://fcdn.singtown.com/b2b9accf-1b16-4d1c-95f3-08f94d124950.png)
    • Traceback (most recent call last):
      File "", line 32, in
      TypeError: extra keyword arguments given
      OpenMV v4.5.4; MicroPython v1.22-omv.r22; OPENMV4P-STM32H743
      Type "help()" for more information.
    • set_auto_gain这一行删除
