为什么我用颜色形状同时识别时候,检测两边的图像那么费劲,有改善解决的办法嘛
import sensor, image, time from machine import UART sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking uart = UART(3,19200) clock = time.clock() while(True): clock.tick() img = sensor.snapshot().lens_corr(strength = 1.5, zoom = 1.0) for c in img.find_circles(threshold = 3500, x_margin = 2, y_margin = 2, r_margin = 10, r_min = 2, r_max = 100, r_step = 2): area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r()) #area为识别到的圆的区域,即圆的外接矩形框 statistics = img.get_statistics(roi=area)#像素颜色统计 if 20<statistics.l_mode()<100 and -30<statistics.a_mode()<0 and -10<statistics.b_mode()<51:#if the circle is red img.draw_circle(c.x(), c.y(), c.r(), color = (0, 255, 0))#识别到的红色圆形用红色的圆框出来 print("已找到目标!") print(c.x(),c.y()) if (c.x()<70): { print("a") } elif(c.x()>90): { print("c") } elif(70<c.x()<90): print("b") else: img.draw_rectangle(area, color = (255, 255, 255)) print("找劈叉了") #将非红色的圆用白色的矩形框出来 uart.write("Hello World!\r") time.sleep_ms(10) #print("FPS %f" % clock.fps()) #roi=(66, 99, -19, -2, -2, 31) #(25, 61, -25, -9, -1, 52)
我没找到什么问题。。。
