  • 下载代码后Open MV指示灯不亮不知道是否在工作,是代码问题吗
      from pyb import Pin
      import math
      threshold_index = 0
      thresholds = [
          (34, 82, -32, -12, -13, 31),
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False)
      pin0 = Pin("P0", Pin.OUT_PP, Pin.PULL_NONE)
      pin1 = Pin("P1", Pin.OUT_PP, Pin.PULL_NONE)
      LED1 = Pin("P2", Pin.OUT_PP, Pin.PULL_NONE)
      LED2 = Pin("P3", Pin.OUT_PP, Pin.PULL_NONE)
          for blob in img.find_blobs(
                  [thresholds[threshold_index]],
                  pixels_threshold=200,
                  area_threshold=200,
                  merge=True,
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255, 0, 0))
                  img.draw_line(blob.major_axis_line(), color=(0, 255, 0))
                  img.draw_line(blob.minor_axis_line(), color=(0, 0, 255))
                  img.draw_keypoints(
                      [(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20
                  if detected :
                      pin1.value(1)
                      LED1.value(1)
                      time.sleep(30)
                      pin1.value(0)
                      LED1.value(0)
                      pin0.value(1)
                      LED2.value(1)
                      time.sleep(30)
    • OpenMV的LED需要代码控制。你的代码不会亮灯。
