为什么我框出来贴标签的这个物体识别以后框选的和视频交通里面不同,没有将整个瓶子框选,返回中心坐标
请在这里粘贴代码 ```# Edge Impulse - OpenMV Object Detection Example import sensor, image, time, os, tf, math, uos, gc sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((240, 240)) # Set 240x240 window. sensor.skip_frames(time=2000) # Let the camera adjust. net = None labels = None min_confidence = 0.5 try: # load the model, alloc the model file on the heap if we have at least 64K free after loading net = tf.load("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024))) except Exception as e: raise Exception('Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')') try: labels = [line.rstrip('\n') for line in open("labels.txt")] except Exception as e: raise Exception('Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')') colors = [ # Add more colors if you are detecting more than 7 types of classes at once. (255, 0, 0), ( 0, 255, 0), (255, 255, 0), ( 0, 0, 255), (255, 0, 255), ( 0, 255, 255), (255, 255, 255), ] clock = time.clock() while(True): clock.tick() img = sensor.snapshot() # detect() returns all objects found in the image (splitted out per class already) # we skip class index 0, as that is the background, and then draw circles of the center # of our objects for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])): if (i == 0): continue # background class if (len(detection_list) == 0): continue # no detections for this class? print("********** %s **********" % labels[i]) for d in detection_list: [x, y, w, h] = d.rect() center_x = math.floor(x + (w / 2)) center_y = math.floor(y + (h / 2)) print('x %d\ty %d' % (center_x, center_y)) img.draw_circle((center_x, center_y, 12), color=colors[i], thickness=2) print(clock.fps(), "fps", end="\n\n")
FOMO模型只是关键点检测,只能得到位置,不能得到大小。
我推荐一个新产品,星瞳AI视觉模组,性能好很多,可以跑yolo: https://singtown.com/product/50933/singtown-ai-vision-module-sc1/
@kidswong999 我看他官方视频里那个交通信号识别的,识别出来的就是框出来的大小,这是为什么啊
@kidswong999那我能用openmv通过训练后,进行目标物体的检测,返回中心点xy坐标以及整个物体长度宽度的参数,后面要用机械臂进行夹取
FOMO模型只是关键点检测,只能得到位置,不能得到大小。所以你不能获得物体长度宽度。
交通信号识别也不能获得大小。视频里说了不能获得大小,3分25秒处
https://singtown.com/learn/50918/
