  • 识别颜色和框选目标不准确
      import ustruct
      #sensor.set_auto_exposure(False)
      state="now"
      last_state="once"
      flag=0
      code=0
      green_threshold = (30, 71, -42, 5, -17, 28)  #绿色阈值
      yellow_threshold = (66, 100, -30, 19, -6, 50)  #黄色阈值
      thresholds = [yellow_threshold, green_threshold]
      uart = UART(3,9600)   #定义串口3变量
      uart.init(9600, bits=8, parity=None, stop=1) # init with given parameters
      def find_max(blobs, min_size=0):
          if not blobs:  # 处理空列表情况
              return None
          max_blob = None
          max_size = 10000# 初始化为最小像素数量
              size = blob.pixels()  # 获取像素数量
              if size > max_size:  # 增加对最小像素数量的判断
                  max_blob = blob
                  max_size = size
      def send_data_packet(code):
          print(f"已发送类型{code}")
          uart.write(str(code))#串口发送
          blobs = img.find_blobs(thresholds);
          cx=0;cy=0;
              max_b = find_max(blobs)
              if max_b:
                  img.draw_rectangle(max_b[0:4]) #用矩形标记出目标颜色区域
                  img.draw_cross(max_b[5], max_b[6]) #在目标颜色区域的中心画十字形标记
                  cx=max_b[5];
                  cy=max_b[6];
                  cw=max_b[2];
                  ch=max_b[3];
                  code=max_b[8];
                  state=str(code)
                  if last_state!=state:
                  last_state=state
                  istate="now"
                  last_state="once"
    • 应该是颜色阈值没选好。
