  • Wifi模块自建热点之后只有一台设备能连接,应该如何解决 ?
    • Face recognition with LBP descriptors.
      See Timo Ahonen's "Face Recognition with Local Binary Patterns".
      Before running the example:
      1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip
      2) Exract and copy the orl_faces directory to the SD card root.
      import network, usocket, json
      Wi-fi和服务器配置
      SSID = 'OPENMV_AP' # Network SSID
      KEY = '1234567890' # Network key (must be 10 chars)
      HOST = '192.168.1.100' # Use first available interface
      PORT = 5000 # Arbitrary non-privileged port
      sensor.set_contrast(3)
      初始化AP模块
      wlan.start_ap(SSID, key=KEY, security=wlan.WPA2, channel=2)
      加载Haar算子
      默认情况下,这将使用所有阶段,更低的satges更快,但不太准确。
      print(face_cascade)
      FPS clock
      #SUB = "s1"
      NUM_SUBJECTS = 5 #图像库中不同人数,一共6人
      def min(pmin, a, s):
      global num
      if a<pmin:
      pmin=a
      num=s
      return pmin
      id-摄像头标号 userId-识别到的用户id
      def send_data_to_server(id,userId):
      # Create a socket to connect to the server
      s.connect((HOST, PORT))
      # Create the JSON payload with id and user_id
      payload = json.dumps({"id":str(id),"userId":str(userId)})
      # Send the POST request to the server with the specific path and data
      s.send("POST /openmv/receive HTTP/1.0\r\n")
      s.send("Content-Type: application/json\r\n")
      s.send("Content-Length: {}\r\n\r\n".format(len(payload)))
      s.send(payload)
      s.close()
      except OSError as e:
      print("Failed to connect to server:", e)
      # 拍摄当前人脸。
      for r in objects:
      img.draw_rectangle(r)
      #d0为当前人脸的lbp特征
      img = None
      pmin = 999999
      num=0
      dist = 0
      #d1为第s文件夹中的第i张图片的lbp特征
              print(num) # num为当前最匹配的人的编号
              send_data_to_server(1,num)# 将匹配到的人脸发送给服务器
              sensor.skip_frames(time = 3000)
    • 你好,你那边wifi模块能进行openmv无线调试吗,我连上wifi后电脑软件没有wifi的图标
    • WiFi扩展板热点模式只能连接一个设备。这个是硬件限制的,解决不了。
