  • 如何实现上电自动录制视频并保存
    • 通电时开启自动录制
      实现每五分钟保存视频到sd卡
      import sensor
      import mjpeg
      import machine
      sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
      sensor.skip_frames(time=2000)  # Wait for settings take effect.
      led = machine.LED("LED_RED")
          led.on()
          for i in range(5*60*30):
          m.close(clock.fps())
          led.off()
          print("saved")
