单个颜色识别,怎么把识别结果通过0/1的形式传递出来(0区域内没指定颜色,1区域内有指定颜色),而不是输出FPS
import sensor import time import math # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green things. You may wish to tune them... thresholds = [ ( 30, 100, 15, 127, 15, 127, ), # generic_red_thresholds -> index is 0 so code == (1 << 0) (30, 100, -64, -8, -32, 32), ] # generic_green_thresholds -> index is 1 so code == (1 << 1) # Codes are or'ed together when "merge=True" for "find_blobs". sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time=2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. "merge=True" must be set to merge overlapping color blobs for color codes. while True: clock.tick() img = sensor.snapshot() for blob in img.find_blobs( thresholds, pixels_threshold=20, area_threshold=20, merge=True ): img.draw_rectangle (blob.rect()) img.draw_cross (blob.cx(),blob.cy()) print(clock.fps())
blobs = img.find_blobs( thresholds, pixels_threshold=20, area_threshold=20, merge=True ) if blobs: print("1") else: print("0") for blob in blobs: img.draw_rectangle (blob.rect()) img.draw_cross (blob.cx(),blob.cy())
