  • 电赛E题,识别“黑色矩形边框”例程(find_rects)修改而来,但是修改后"黑色矩形边框"识别率低,甚至误识别
    • import time, sensor
      THRESHOLD_R = [(87, 99, -26, 80, -55, 37)]
      THRESHOLD_G = [(57, 100, -45, 18, -45, 43)]
      THRESHOLD = 125
      DIV_TASK_2 = 10
      DIV_TASK_3 = 20
      ROI = (10, 10, 90, 90)
      def sending_data(dx, dy):
          global uart
          flx = 0
          fly = 0
          if dx < 0:
              dx = -dx
              flx = 1
          if dy < 0:
              dy = -dy
              fly = 1
          FH = bytearray([0xA1, 0x02, flx, dx, fly, dy, 0x1A])
          uart.write(FH)
      uart = UART(3,115200)
      sensor.set_windowing((120, 120))
      sensor.set_auto_whitebal(True)
      sensor.skip_frames(time = 20)
      sensor.set_hmirror(False)
      sensor.set_vflip(True)
      sensor.set_auto_exposure(False,1000)
      #lcd.init()
      cnt_find_rect = 0
      p_array = []
      flgstart = 0
      flgend = 0
      flgend3 = 0
      cnt = 0
      err_dx = 0
      err_dy = 0
      task = b'0'
      goal_task2 = 0
      goal_task3 = 0
      goal_task4 = 0
      cx_screen = 60
      cy_screen = 60
      p0 = (97, 19)
      p1 = (19, 22)
      p2 = (20, 98)
      p3 = (98, 98)
      d0 = (93, 21)
      d1 = (51, 22)
      d2 = (52, 51)
      d3 = (93, 50)
      point_temp = []
          if uart.any():
              task = uart.read(1)
              FH = bytearray([0xA1,0x33,0X1A])
              uart.write(FH)
          blobs = img.find_blobs(THRESHOLD_R, pixels_threshold = 1, area_threshold = 1)
          blob = []
          for b in blobs:
              img.draw_rectangle(b.rect(), color = (0, 255, 0), scale = 1, thickness = 1)
          for b in blobs:
              if b.pixels() > max_size:
                  blob = b
                  max_size = b.pixels()
          if blob:
              cx = blob[0] + int(blob[2] / 2)
              cy = blob[1] + int(blob[3] / 2)
          if task == b'1':
              img.draw_string(0, 0, "task:1")
              img.draw_cross(point_temp[0][0], point_temp[0][1])
              if blob:
                  err_dx = cx - point_temp[0][0]
                  err_dy = cy - point_temp[0][1]
                  if abs(err_dx) < 1 and abs(err_dy) < 1:
                      task = b'0'
                      FH = bytearray([0xA1, 0x11, 0x1A])
                      uart.write(FH)
                      print('1')
              sending_data(err_dx, err_dy)
          elif task == b'2':
              img.draw_string(0, 0, "task:2")
              points = (point_temp[1], point_temp[2], point_temp[3], point_temp[4])
              if blob:
                  err_dx = cx - points[goal_task2][0]
                  err_dy = cy - points[goal_task2][1]
                  if goal_task2 == 1:
                      err_dy = 0
                  elif goal_task2 == 2:
                      err_dx = 0
                  elif goal_task2 == 3:
                      err_dy = 0
                  elif goal_task2 == 0 and flgend == 1:
                      err_dx = 0
                  print(err_dx, err_dy)
                  if abs(err_dx) < 2 and abs(err_dy) < 2:
                      goal_task2 = goal_task2 + 1
                      if goal_task2 == 4:
                          flgend = 1
                          goal_task2 = 0
                      elif flgend == 1:
                          task = b'0'
                          goal_task2 = 0
                          uart.write(FH)
                          print("OK")
                          flgend = 0
          elif task == b'4' or task == b'3':
              if cnt_find_rect > 10 and flgstart == 0:
                  flgstart = 1
                  corner_cx = int((corner[3][0] + corner[2][0] + corner[1][0] + corner[0][0]) / 4)
                  corner_cy = int((corner[3][1] + corner[2][1] + corner[1][1] + corner[0][1]) / 4)
                  corner_temp = []
                  for i in range(4):
                      dx = corner_cx - corner[i][0]
                      dy = corner_cy - corner[i][1]
                      x = corner[i][0] + int(dx * 0.06)
                      y = corner[i][1] + int(dy * 0.08)
                      corner_temp.append((x, y))
                  corner = corner_temp
                  p_array.append(corner[0])
                  for i in range(4):
                      next = i + 1
                      if i == 3:
                          next = 0
                      dy = (corner[next][1] - corner[i][1]) / DIV_TASK_3
                      dx = (corner[next][0] - corner[i][0]) / DIV_TASK_3
                      for j in range(DIV_TASK_3):
                          pointx = int(corner[i][0] + dx * (j + 1))
                          pointy = int(corner[i][1] + dy * (j + 1))
                          p_array.append((pointx, pointy))
                  print(len(p_array))
                  for p in p_array:
                      img.draw_circle(p[0], p[1], 1)
              elif flgstart == 0:
                  rects = img.find_rects(threshold = 200) #ROI=(80, 60, 80, 60)
                  for r in rects:
                      rect = r.rect()
                      if (rect[0] > 15 and rect[1] > 15
                          and rect[2] < 60 and rect[3] < 60
                          and (rect[0] + rect[2]) < 100
                          and (rect[1] + rect[3]) < 100
                          and (rect[0] + rect[2]) > 25
                          and (rect[1] + rect[3]) > 25):
                          cnt_find_rect = cnt_find_rect + 1
                          img.draw_rectangle(rect, color = (255, 0, 0))
                          corner = r.corners()
                          for point in r.corners():
                              img.draw_circle(point[0], point[1], 5, color = (0, 255, 0))
                          break
              print(len(p_array))
              if blob and flgstart == 1:
                  print(goal_task4)
                  err_dx = cx - p_array[goal_task4][0]
                  err_dy = cy - p_array[goal_task4][1]
                      goal_task4 = goal_task4 + 1
                      if goal_task4 == len(p_array):
                          task = b'0'
                          goal_task4 = 0
                          uart.write(FH)
                          print("OK")
                          flgstart = 0
                          p_array = []
                          cnt_find_rect = 0
              if flgstart == 1:
          elif task == b'9':
              point_temp.append((cx, cy))
              img.draw_string(0, 0, "task:5")
              for p in point_temp:
              FH = bytearray([0xA1, 0x44, 0x1A])
              uart.write(FH)
              task = b'0'
          elif task == b'6':
              img.draw_string(0, 0, "task:6")
          #lcd.display(img)
    • 你的代码我没办法测试,你把串口的部分删掉,只留需要的部分。
    • @kidswong999
      这个是识别黑色矩形边框部分,我的程序只是识别黑色矩形边框时,识别不出来。但是这个程序需要外部串口通信来触发这个任务3,去识别黑色边框
      for r in rects:
      rect = r.rect()
      break
      print(len(p_array))
    • 你把程序删减好,改成能够直接运行的。
    • if (rect[0] > 15 and rect[1] > 15
      这句话的作用是什么?是不是这一堆判断写错了,把它删掉看看。
          for r in rects:
              rect = r.rect()
      #        if (rect[0] > 15 and rect[1] > 15
      #            and rect[2] < 60 and rect[3] < 60
      #            and (rect[0] + rect[2]) < 100
      #            and (rect[1] + rect[3]) < 100
      #            and (rect[0] + rect[2]) > 25
      #            and (rect[1] + rect[3]) > 25):
