  • openmv怎么识别物体后求出相应的坐标?求大佬解答
    • import sensor, image, time, os, tf, uos, gc
      sensor.skip_frames(time=2000)
      net = None
      labels = None
      except Exception as e:
          print(e)
              # 获取物体的坐标
              cx = x + (w // 2)
              cy = y + (h // 2)
              print("物体坐标:({},{})".format(cx, cy))
          print(clock.fps(), "fps")
    • 你的代码是分类,你要用FOMO目标点检测。https://singtown.com/learn/50918/
