教程里的lcd是不是无法使用了?
https://book.openmv.cc/shield/lcd.html
# LCD Example # # Note: To run this example you will need a LCD Shield for your OpenMV Cam. # # The LCD Shield allows you to view your OpenMV Cam's frame buffer on the go. import sensor, image import lcd sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # or sensor.GRAYSCALE sensor.set_framesize(sensor.QQVGA2) # Special 128x160 framesize for LCD Shield. lcd.init() # Initialize the lcd screen. #lcd初始化 while(True): lcd.display(sensor.snapshot()) # Take a picture and display the image. #将图像显示在lcd中
4.5.0的lcd有bug,建议先用4.4.3的固件。
4.5.1发布后会更新新的例子代码。
