官方例程报错 no module named 'display'
import sensor import display sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # or sensor.GRAYSCALE sensor.set_framesize(sensor.QQVGA2) # Special 128x160 framesize for LCD Shield. lcd = display.SPIDisplay() # Initialize the lcd screen. while True: lcd.write(sensor.snapshot()) # Take a picture and display the image.
貌似删了注册表的东西,重装ide也一样报错。
