  • 请问在色块识别程序中,锚定框将非选定颜色的物品框住后,添加什么程序可以让锚定框与锚定框间不重合?
    • import sensor
      import image
      import math
      import lcd
      threshold_index = 0
      thresholds = [(72, 40, -29, 60, -62, -2)]
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False) # 关闭增益
      sensor.set_auto_whitebal(False) # 关闭白平衡
      lcd.init()
      roi = (0, 0, 320, 240)
      blue_threshold = (72, 40, -29, 60, -62, -2)
      detected_rectangles = []  # 添加一个保存矩形的列表
      # 定义矩形重叠函数
      def rectangle_overlap(rect1, rect2):
          x_overlap = max(0, min(rect1[0] + rect1[2], rect2[0] + rect2[2]) - max(rect1[0], rect2[0]))
          y_overlap = max(0, min(rect1[1] + rect1[3], rect2[1] + rect2[3]) - max(rect1[1], rect2[1]))
          overlap_area = x_overlap * y_overlap
          rect1_area = rect1[2] * rect1[3]
          rect2_area = rect2[2] * rect2[3]
          return overlap_area > 0 and overlap_area / min(rect1_area, rect2_area) > 0.5
          time.sleep(2)
          img = img.crop(roi)
          blobs = img.find_blobs([blue_threshold])
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=50, area_threshold=50, invert=True, merge=False):
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255, 0, 0))
                  img.draw_line(blob.major_axis_line(), color=(0, 255, 0))
                  img.draw_line(blob.minor_axis_line(), color=(0, 0, 255))
              current_rectangle = blob.rect()  # 记录当前矩形
              is_overlap = False
              for rectangle in detected_rectangles:
                  if rectangle_overlap(current_rectangle, rectangle):
                      is_overlap = True
                      break
              if not is_overlap:
                  detected_rectangles.append(current_rectangle)  # 将矩形添加到列表中
          print("target count:", len(detected_rectangles))  # 统计矩形个数
          lcd.display(img)
    • 我没听懂,”锚定框与锚定框间不重合“是什么意思?
