  • 查找圆形图案中心坐标报错
    • def main():
       global Bd_num
       print("Initial exposure == %d" % sensor.get_exposure_us())
       print("db == %d" % sensor.get_gain_db())
       sensor.skip_frames(time = 500)
       sensor.set_auto_gain(False![0_1698112339282_捕获.PNG](https://fcdn.singtown.com/bccd10ae-cfa4-4438-8179-f86bc66a7530.PNG) )
       sensor.set_auto_exposure(False,exposure_us=2000)
      # sensor.set_hmirror(True)
      # sensor.set_vflip(True)
       uart2 = pyb.UART(3)
       uart2.init(115200, bits=8, parity=None, stop=1,read_buf_len=500)
          print(clock.fps(),sensor.get_rgb_gain_db())
          for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2):
              print(c)
    • 你得把完整的,可以直接运行出错的代码放上来。
    • from pyb import UART
      import sensor, image, time,pyb,struct
      import cpufreq
      EXPOSURE_TIME_SCALE = 1.0
      def main():
       sensor.set_auto_gain(False)
       sensor.skip_frames(time = 2000)#跳过多少毫秒的帧
       uart2 = pyb.UART(3)
             print(c)
      main()
    • OpenMV4 H7,find_circles不能用vga图像,因为内存太小了。
      要么减小分辨率,要么换OpenMV4 H7 Plus。
    • @kidswong999 请问用findcircles()函数是不是需要知道圆大概占多少像素?
