  • 为什么串口接收数据一段好的一段又隔开了正常是0.774536?
      thresholds = [(0, 100, 8, 123, -3, 127), #red
                    (9, 96, -128, 111, -81, -17), #blue
                    (0, 97, -127, -15, 127, -128)] #green
      import ustruct,sensor,image,time
      from machine import UART
      from pyb import Servo
      #time.sleep(17)
      sensor.skip_frames(10)
      #初始化串口
      uart = UART(1, 115200)   #串口1发送到单片机串口4
      #端口定义
      s1 = Servo(1) # servo on position 1 (P7)
      s2 = Servo(2) # servo on position 1 (P8)
      #函数初始化
      chucun = 0
      zhuangtaiji = 0
      zhuangtaiji2 = 0
      zhuangtaiji3 = 0
      a = 0
      b = 0
      s2.angle(-90)
      time.sleep(1)
      s1.angle(-90) # move to 45 degrees
      time.sleep(1)
       flag = 0
       for blob in img.find_blobs(thresholds,x_stride=80,y_stride=80,pixels_threshold=32500,area_threshold=30000, merge = False):
          if int(blob.code()) == 1:
           img.draw_string(10,10,"red",color=(255,0,0),scale = 2)
           flag = 1
          if int(blob.code()) == 2:
           img.draw_string(10,10,"blue",color=(0,0,255),scale = 2)
           flag = 2
          if int(blob.code()) == 4:
           img.draw_string(10,10,"green",color=(0,255,0),scale = 2)
           flag = 4
       if uart.any():
           a = uart.readline().decode().strip()
      #     re.match chucun:
      #     case 0:
       if(flag == 0 and zhuangtaiji2 == 1):
          zhuangtaiji = 1
       if(flag == 1 or flag == 2 or flag == 4):
          if(chucun == 0):
              chucun = flag
              zhuangtaiji2 = 1
          if(chucun == flag and zhuangtaiji == 1 and zhuangtaiji3 == 0):
              uart.write((ustruct.pack("<BBBB",0X5C,0X5A,flag,0x5B)))
              time.sleep(0.5)
              s1.angle(90)
              time.sleep(1)
              s1.angle(-90)
              time.sleep(1)
              zhuangtaiji3 =0
       print (float(a))
    • uart.init(115200, bits=8, parity=None, stop=1)
      改为
      uart.init(115200, bits=8, parity=None, stop=1, timeout_char=1000)
