  • 输入代码报错后出现image object has no attribute find,但固件是最新版本,是什么原因?
    • image object has no attribute find
    • # Hello World Example
      thresholds=(100, 0, 127, 30, -87, 104) # generic_red_thresholds
      sensor.set_auto_gain(False)
          for blob in img.find.blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True):
              img.draw_cross(blob.cx(),bolb.cy())
    • img.find.blobs 改为 img.find_blobs
