  • 请问为什么运行这个多颜色识别的代码会出现多个框框出来,请问如何消除其他框呢?
      请问为什么运行这个多颜色识别的代码会出现多个框框出来,明明只有这个红色才需要框出来的,请问如何消除其他框呢?而且还有在白框中有其他彩色的线出来,为什么有这些红蓝绿的线,他们起什么作用呢对颜色识别?可以不要消除吗?
      # Multi Color Blob Tracking Example
      # This example shows off multi color blob tracking using the OpenMV Cam.
      # The below thresholds track in general red/green things. You may wish to tune them...
                    (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      # You may pass up to 16 thresholds above. However, it's not really possible to segment any
      # scene with 16 thresholds before color thresholds start to overlap heavily.
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
          for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200):
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255,0,0))
                  img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  img.draw_line(blob.minor_axis_line(), color=(0,0,255))
    • 很简单,阈值不对。
      你这个是三个颜色的阈值。
      参考视频:https://singtown.com/learn/49993/
    • @kidswong999 可是我是想多颜色识别的,所以设三个阈值啊,每个颜色能识别的阈值是设置好的,可为什么会出现那么多白框呢?
