  • 为什么写入for循环break之后还是重复识别
    • import time, sensor, image, math
      import sensor, image, math
      uart = UART(3, 9600)
      thresholds_red = [(18, 46, -4, 26, 5, 30)] # generic_red_thresholds
      thresholds_green =  [(47, 64, -67, -39, -128, 127)] # generic_green_thresholds
      thresholds_blue = [(24, 38, -128, 36, -73, -10)] # generic_blue_thresholds
      cx = 0, # up sample by 4   #数据1
      cy = 0, # up sample by 4    #数据2
      cw = 0, # up sample by 4    #数据1
      ch = 0, # up sample by 4    #数据2
      cj = 0, # up sample by 4    #数据1
      cz = 0, # up sample by 4    #数据2
      def cx1():
          for cx in tuple1:
              if cx == 1 :
                  for blob in img.find_blobs(thresholds_red, pixels_threshold=200, area_threshold=200):   #未设置roi
                      if blob.elongation() > 0.5:
                          img.draw_edges(blob.min_corners(), color=(255,0,0))
                          img.draw_line(blob.major_axis_line(), color=(0,255,0))
                          img.draw_line(blob.minor_axis_line(), color=(0,0,255))
                          img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)                #识别寻找红色色块
                          uart.write('r')#发送完成信号
                          print("cx=red")
                          break
              elif cx == 2 :
                  for blob in img.find_blobs(thresholds_green, pixels_threshold=200, area_threshold=200):   #未设置roi
                          img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)                #识别寻找绿色色块
                          uart.write('g')#发送完成信号
                          print("cx=green")
                          break
              elif cx == 3:
                  for blob in img.find_blobs(thresholds_blue, pixels_threshold=200, area_threshold=200):   #未设置roi
                          img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)                #识别寻找蓝色色块
                          uart.write('b')#发送完成信号
                          print("cx=blue")
                          break
              print(code)
              qrcode2 = code.payload()
              cx = int(qrcode2[0:1])
              cy = int(qrcode2[1:2])
              cw = int(qrcode2[2:3])
              ch = int(qrcode2[4:5])
              cj = int(qrcode2[5:6])
              cz = int(qrcode2[6:7])
              print('读取')
              print(qrcode2)
              list1 = list(qrcode2)
              time.sleep(5)
              tuple1 = (cx, cy, cw, ch, cj, cz)
              print(tuple1)
              print(cx)
              cx1()
              print(cx)
              cy1()
              print(cy)
    • 你的break只会跳出一层for的循环,我猜你想用return。
