  • clock = time.clock() 是什么意思?
    • # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      thresholds = [(67, 82, -128, 127, 28, 127)] # generic_red_thresholds   阈值设置,代表LAB的最大值和最小值
      sensor.reset()  #重置感光元件/重置摄像机
      sensor.set_pixformat(sensor.RGB565) #设置模式为彩图
      sensor.set_framesize(sensor.QVGA)   #设置图像大小为QVGA
      sensor.skip_frames(time = 2000)     #使以上操作生效
      sensor.set_auto_gain(False) # must be turned off for color tracking     关闭颜色增益
      sensor.set_auto_whitebal(False) # must be turned off for color tracking 关闭白平衡
          clock.tick()    #开始追踪运行时间
          img = sensor.snapshot()     #在感光元件截取一张图
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=320, area_threshold=400, merge=True):
              #img.find_blobs()函数创建一个class image.blob对象,返回一个包含多个元素的字典
              if blob.elongation() > 0.5:     #返回一个介于0和1之间的值,该值表示对象的长度(不是圆形)。一条线将是1。
                  img.draw_edges(blob.min_corners(), color=(255,0,0))
                  img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  img.draw_line(blob.minor_axis_line(), color=(0,0,255))
              img.draw_rectangle(blob.rect())         #识别到颜色则画框框起
              img.draw_cross(blob.cx (), blob.cy())   #识别到颜色则画十字
              print(blob)
      #    print(clock.fps())#停止追踪运行时间,并返回当前帧数
