  • 如何定时500毫秒串口发送数据
    • 如何定时500毫秒串口发送数据,Timer类给的示例运行不成功
    • import sensor, image
      import pyb
      last_time = pyb.millis()
          if pyb.millis() - last_time > 500:
              print('send')
    • 你好,试了一下这个定时500ms会因程序周期变化而变化,中断定时给其它单片机通讯改怎么写呢?谢谢!!!
    • import time
      from pyb import Timer
      uart = UART(3, 19200)
      data_bytes = b'123456'
      # we will receive the timer object when being called
      # Note: functions that allocate memory are Not allowed in callbacks
      def tick(timer):
          global data_bytes
          global uart
          print(data_bytes)
          uart.write(data_bytes)
      tim = Timer(2, freq=2)  # create a timer object using timer 2 - trigger at 1Hz
      tim.callback(tick)  # set the callback to our tick function
          time.sleep_ms(1000)
          data_bytes = b'654321'
          time.sleep_ms(1000)
