  • 需要一个缓冲区协议的对象,这个怎么解决
    • ![0_1692785268446_报错.jpg](正在上传 72%)
      import sensor, image, time, os, tf, uos, gc,pyb,machine
      uart = UART(3,115200)
      green = (10,100,-50,15,-15,50)
      red = (0,100,-30,50,-30,30)
      blue = (10,100,-20,40,-10,40)
      orange = (10,80,-10,30,-20,35)
      brown = (0,80,-10,20,-20,30)
      yellow = (50,80,-10,10,-20,60)
      white = (10,100,-20,30,-30,20)
      gray = (20,80,-10,15,-10,25)
      sensor.set_auto_gain(False)
      name = 'c'
          def rubbish():
              net = None
              labels = None
                  net = tf.load("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64 * 1024)))
              except Exception as e:
                  raise Exception(
                      'Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(
                          e) + ')')
                  raise Exception(
                      'Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(
                          e) + ')')
              image = sensor.snapshot()
              scores = net.classify(image)
              for obj in net.classify(image, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
                  image.draw_rectangle(obj.rect())
                  name = predictions_list[0][0]
                      max = 0.8
                      if predictions_list[i][1] > max:
                          max = predictions_list[i][1]
                          name = predictions_list[i][0]
                  if name == 'KHSLJ':
                      name = 'k'
                  elif name == 'YHLJ':
                      name = 'y'
                  elif name == 'CYLJ':
                      name = 'c'
                  elif name == 'QTLJ':
                      name = 'q'
              return name
          blobs1 = img.find_blobs([green])
          blobs2 = img.find_blobs([red])
          blobs3 = img.find_blobs([blue])
          blobs4 = img.find_blobs([orange])
          blobs5 = img.find_blobs([brown])
          blobs6 = img.find_blobs([yellow])
          blobs7 = img.find_blobs([white])
          blobs8 = img.find_blobs([gray])
          if blobs1:
              rubbish()
              uart.write(name)
          if blobs2:
              rubbish()
              uart.write(name)
          if blobs3:
              rubbish()
              uart.write(name)
          if blobs4:
              rubbish()
              uart.write(name)
          if blobs5:
              rubbish()
              uart.write(name)
          if blobs6:
              rubbish()
              uart.write(name)
          if blobs7:
              rubbish()
              uart.write(name)
          if blobs8:
              rubbish()
              uart.write(name)
    • 你把name打印出来看看是啥。
          def rubbish():
              net = None
              labels = None
                  raise Exception(
                          e) + ')')
                  raise Exception(
                          e) + ')')
                      max = 0.8
                  if name == 'KHSLJ':
                      name = 'k'
                      name = 'y'
                      name = 'c'
                      name = 'q'
              return name
          name = rubbish()
          if blobs1:
              rubbish()
              uart.write(name)
              print(name)
          if blobs2:
              rubbish()
              uart.write(name)
          if blobs3:
              rubbish()
              uart.write(name)
          if blobs4:
              rubbish()
              uart.write(name)
          if blobs5:
              rubbish()
              uart.write(name)
          if blobs6:
              rubbish()
              uart.write(name)
          if blobs7:
              rubbish()
              uart.write(name)
          if blobs8:
              rubbish()
              uart.write(name)
    • 前面打印name 一直是'c',我就把代码改成这样了,又提示了这个错误
    • tf.load不要在死循环里调用,只需要在一开始调用一次。
