  • 脱机运行识别率太低,有六种图像通过edge impulse训练之后只能识别两种,图像2识别成图像3
      net = None
      labels = None
      except Exception as e:
          print(e)
          uart = UART(3,9600)
              predictions_list=sorted(predictions_list,key=lambda x:x[1],reverse=True)
              highest_prediction=predictions_list[0]
              print("The highest prediction is:%s=%f"%(highest_prediction[0],highest_prediction[1]))
              uart.write(highest_prediction[0])
              uart.write("\r\n")
    • 增加图像数量,每个分类1000张,不同的角度,位置和光线都要。
