  • 摄像头
    • 为什么有时候,在IDE里面看到的图像会泛红色呢,这是什么原因呢
    • 你用的是什么代码?
      请运行hello world
      http://book.openmv.cc/example/01-Basics/helloworld.html
    • 不是每次都会出现这种情况,只是偶尔会出现
    • 请提供出现这种现象的具体代码。
    • import sensor, image, time ,math
      red_threshold   = (100, 38, 9, 51, 47, -82)
      yellow_threshold = (100, 6, -40, -11, -69, 116)
      black_threshold =(0, 25, -31, 26, 25, -44)
      sensor.skip_frames(50)
      def find_red(blobs):
          max_size = 0
          return max_size
      def line_filter_copy(src, dst):
        for i in range(0, len(dst), 1):
            dst[i] = src[i<<1]
      def line_filter_bw(src, dst):
            if (src[i<<1] > 200 and src[i<<1] < 255):
                dst[i] = 0xFF
                dst[i] = 0x00
      i = 0
      max_number = 0
          lines = 0
          img = sensor.snapshot(line_filter = line_filter_copy)
          black_blobs = img.find_blobs([black_threshold])
          red_blobs = img.find_blobs([red_threshold])
          if black_blobs:
              max_blob=find_max(black_blobs)
              #print('sum :', len(blobs))
              if i == 0:
              else :
                  pass
              bx_x=max_blob.cx()-160
              by_y=120-max_blob.cy()
              x=math.fabs(bx_x)
              y=math.fabs(by_y)
              if 0 <= x < 10 :
                  bx_value = 1
              elif 10 <= x < 100 :
                  bx_value = 2
              else :
                  bx_value = 3
              if 0 <= y < 10 :
                  by_value = 1
              elif 10 <= y < 100 :
                  by_value = 2
              else :
                  by_value = 3
              b_output_str="x%d%d,y%d%d" % (bx_value,bx_x,by_value,by_y)
              #print('you send:',b_output_str)
              #uart.write(b_output_str+'\r\n')
              print('not found!')
              b_output_str = "0"
          #img = sensor.snapshot()
          #blobs = img.find_blobs([yellow_threshold])
          if red_blobs:
              max_blob=find_max(red_blobs)
              max_number=find_red(red_blobs)
              if i == 1 :
              else :
                  pass
              x=math.fabs(x_x)
              y=math.fabs(y_y)
              if 0 <= x < 10 :
                  x_value = 1
                  x_value = 2
              else :
                  x_value = 3
              if 0 <= y < 10 :
                  y_value = 1
                  y_value = 2
              else :
                  y_value = 3
              output_str="x%d%d,y%d%d" % (x_value,x_x,y_value,y_y)
              #print('you send:',output_str)
              #uart.write(output_str+'\r\n')
              #print('not found!')
              output_str = "0"
          #print('max_number:',max_number)
          if max_number > 1250 :
              i = 1
              while(i):
                  lines = 0
                  if red_blobs:
                      if i == 1 :
                      else :
                          pass
                      x=math.fabs(x_x)
                      y=math.fabs(y_y)
                      if 0 <= x < 10 :
                          x_value = 1
                          x_value = 2
                      else :
                          x_value = 3
                      if 0 <= y < 10 :
                          y_value = 1
                          y_value = 2
                      else :
                          y_value = 3
                      output_str = "0"
                  print('you send red:',output_str)
                  if max_number < 100 :
                      i = 0
                  else :
                      i = 1
          else :
              print('you send black:',b_output_str)
              i = 0
          max_number = 0
    • @有点好奇摄像头 中说:
      改成
      sensor.skip_frames(time=2000)
      或者更高
