摄像头采集画面为长方形320*240,如何保持宽度320像素不变,让其变为正方形画面呢?大佬们,求解答??
此回复已被删除!
图片缩放一下就是正方形了。
import sensor, image, time sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) clock = time.clock() while(True): clock.tick() img = sensor.snapshot().scale(x_size=240, y_size=240, copy_to_fb=True) print(img.width(),img.height()) print(clock.fps())
@kidswong999 多谢答疑
