  • 拍好照片上传edge impulse后下载的代码用到openmv时报错,为啥?
      net = None
      labels = None
      min_confidence = 0.5
          # Load built in model
          labels, net = tf.load_builtin_model('trained')
      except Exception as e:
          raise Exception(e)
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • 生成模型的时候,选择OpenMV Library,而不是OpenMV Firmware。
