  • 单独使用串口和串口与i2c一起使用时串口助手收到的数据不一样,请问怎么解决
    • THRESHOLD = (3, 34, -69, 115, -48, 127)
      from pyb import LED
      import math
      from machine import I2C
      from vl53l1x import VL53L1X
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      i2c = I2C(2)
      distance_sensor = VL53L1X(i2c)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
      sensor.set_framesize(sensor.QQQVGA)
      data1 = 0x2c
      data2 = 0x2b
      roi1 = [(0, 0, 25, 20),
              (0, 45, 32, 50),
              (50, 45, 30, 50)
          ROI_L = (22, 31, 4, 5)
          ROI_R = (43, 31, 6, 5)
          ROI1 = (34, 12, 12, 31)
          ROI2 = (27, 45, 15, 15)
          ROI3 = (32, 30, 6, 12)
          blobs1 = img.find_blobs([(100, 100)], roi=ROI_L, area_threshold=15, merge=True)
          blobs2 = img.find_blobs([(100, 100)], roi=ROI_R, area_threshold=15, merge=True)
          blobs3 = img.find_blobs([(100, 100)], roi=ROI1, area_threshold=15, merge=True)
          blobs4 = img.find_blobs([(100, 100)], roi=ROI2, area_threshold=15, merge=True)
          blobs5 = img.find_blobs([(100, 100)], roi=ROI3, area_threshold=15, merge=True)
          line = img.get_regression([(100, 100)], robust=True)
          img.draw_line((25, 0, 25, 60), color=(0, 255, 0))
          img.draw_line((47, 0, 47, 60), color=(0, 255, 0))
          img.draw_line((0, 45, 25, 45), color=(0, 255, 0))
          img.draw_line((47, 45, 80, 45), color=(0, 255, 0))
          if blobs1 and blobs2:
              #print(666)
              output1 = int(50) + 50
              output_str1 = bytearray([output1])
              uart.write('@')
              uart.write(bytearray(b'd'))
              uart.write('\r\n')
          if line:
      		 rho_err = abs(line.rho()) - img.width() / 2
      		 if line.theta() > 90:
      			 theta_err = line.theta() - 180
      			 img.draw_line(line.line(), color=127)
      		 if line.magnitude() > 8:
      			 rho_output = rho_pid.get_pid(rho_err, 1)
      			 theta_output = theta_pid.get_pid(theta_err, 1)
      			 output = rho_output + theta_output
      			 output = int(output) + 50
                               OUTPUT = str(round(output))
                               outut_str = bytearray([output])
                               uart.write(bytes([0x2C]))
                               uart.write(outut_str )
                               uart.write(bytes([0x5B]))  # 将16进制转换为字
                               print(outut_str )
      # 读取测距模块数据
          distance = distance_sensor.read()
          # 对测距数据进行处理
          distance = distance / 10  # 假设测距模块返回的是以毫米为单位的距离数据
          distance = int(distance)
          print("Distance:", distance, "mm")
          outut_str2 = bytearray([distance])
          uart.write(outut_str2 )
          time.sleep(0.1)
    • 原因:串口3和i2c引脚冲突。
      解决办法:把串口3改为串口1,使用P0P1引脚发送串口数据。
