  • openmv和esp32如何实现串口通信
    • 我写的关于串口通信的代码,esp32部分提示uart不存在,openmv部分提示无效语法。
      esp32:
      from machine import Pin,PWM,ADC,SoftI2C
      #from pid import PID
      from ssd1306 import SSD1306_I2C
      from machine import UART
      import sensor, time, os
      #引脚定义
      #电机引脚
      IN1=Pin(8,Pin.OUT)   #右侧电机
      IN2=Pin(9,Pin.OUT)
      IN3=Pin(18,Pin.OUT) #左侧电机
      IN4=Pin(10,Pin.OUT)
      #开关引脚
      KEY=Pin(0,Pin.IN,Pin.PULL_UP) #构建 KEY 对象
      # IN1_pwm=PWM(IN1,duty=298)
      # IN3_pwm=PWM(IN3,duty=280)
      state = 0
      #药品检测引脚
      number_model = 0
      # 应检测到的模板数字初始化为0
      #初始化
      i2c=SoftI2C(sda=Pin(42),scl=Pin(40))
      oled=SSD1306_I2C(128,64,i2c,addr=0x3c)
      uart_tx = UART(43, 9600)
      uart_tx.init(9600, bits=8, parity=None, stop=1)
      uart_rx = UART(44, 9600)
      uart_rx.init(9600, bits=8, parity=None, stop=1)
      def control(KEY):
          global state
          time.sleep_ms(10) #消除抖动
          if KEY.value()==0: #确认按键被按下
              state=not state #使用 not 语句而非~语句很抱歉B
              IN1.value(state)
              IN3.value(state)#LED 状态翻转
      #         IN1_pwm=PWM(IN1,duty=256)
      #         IN3_pwm=PWM(IN3,duty=256)
              IN1.frep(600)
              time.sleep(1)
      #前进
      def Go():
      #     IN1.value(1)
      #     IN3.value(1)
      def left():#左转
          IN1_pwm=PWM(IN3,duty=0)
          IN3_pwm=PWM(IN4,duty=0)
          time.sleep(0.5)
      def right():#右转
          IN1_pwm=PWM(IN1,duty=0)
          IN3_pwm=PWM(IN2,duty=0)
          IN1.value(1)
          IN2.value(1)
          time.sleep(0.5)
      def led():#装好药品后红灯亮起,回到药房处绿灯亮起
      #     if 放药处避障模块给出信号(放上药品):
          if barrier1() == 1:
              led1.value(1)
          if barrier1() == 2:
              led1.value(0)
              return
          #if  flag=1:
       #led2.value(1)
      #倒车,后退
      def Back():
          IN1.value(not state)
          IN3.value(not state)
          return 1
      def stop():
          IN1.value(0)
          IN2.value(0)
          IN3.value(0)
          IN4.value(0)
      #     time.sleep(1)
      def barrier():#返回药盒处的红外避障模块给出的0/1信号
          barrier1=ADC(Pin(6))
      #     return barrier1.read()
          #print(barrier1.read())
          #time.sleep(1)
          #print(barrier1.value())
          if barrier1.read()<1000: #红外避障模块输出为1,已装载药品
              # 装载药品后即开始检测数字
              sensor.reset()                         # 复位和初始化传感器。
              sensor.set_pixformat(sensor.GRAYSCALE)    # Set pixel format to RGB565 (or GRAYSCALE)
              #sensor.set_framesize(sensor.VGA)
              # Set 240x240 window.设置传感器的窗口大小
              # 跳过一定时间内的图像帧
                  img = sensor.snapshot().binary([(0,64)])
                  for obj in tf.classify("trained.tflite", img, min_scale=1.0, scale_mul=0.9, x_overlap=0.0, y_overlap=0.0):
                      output = obj.output()
                      #print(output)
                      #print(max(output))
                      global number_model
                      number_model = output.index(max(output))
                  uart_tx.write(number_model)
              Go()
              oled.fill(0)
              oled.text("The medication",0,20)
              oled.text(" has ready!",0,30)
              oled.show()
              return 1
              stop()
              oled.text("Please put in ",0,20)
              oled.text("the medication!",0,30)
              oled.show()
          #可以不加在定时器,根据车行驶状态来给出调用此函数的位置
      def main():
          KEY.irq(control,Pin.IRQ_FALLING)
          Barrier=Pin(47,Pin.OUT)
          #Barrier.irq(AvoidingObstacles,Pin.IRQ_FALLING)
              #Back()
              barrier()
              #flag = uart_rx.read(10)
              uart_rx.readinto(flag)
              if flag == 'left':
                  left()
              elif flag == 'right':
                  right()
              elif flag == 'Go':
                  Go()
              elif flag == 'stop':
                  stop()
      if __name__ == '__main__':
          main()
      openmv:
      THRESHOLD = (70, 4, 18, 127, -125, 127) # Grayscale threshold for dark things...
      # 灰度阈值
      import sensor, image, time, os, tfe
      uart_rx = UART('P5',9600)
      uart_tx = UART('P4',9600)
      def motor():
          rho_pid = PID(p=0.4, i=0)
          theta_pid = PID(p=0.001, i=0)
          sensor.set_vflip(True)
          # 垂直翻转,从传感器获取的图像或数据在显示或处理时会上下颠倒。
          sensor.set_hmirror(True)
          # 将传感器的图像或数据在水平方向上进行镜像操作(从传感器获取的图像或数据在显示或处理时会左右翻转
          # 设置传感器像素格式
          sensor.set_framesize(sensor.QQQVGA)
          # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000.
          # 设置帧尺寸
          # WARNING: If you use QQVGA it may take seconds
          # 使传感器跳过接下来的2000毫秒内的帧
          # to process a frame sometimes.
          # 创建一个定时器对象
              #number_model = uart_rx.read()
              uart_rx.readinto(number_model)
              # 获取自上次调用tick()方法以来的毫秒数,常用于实现帧率控制或时间延迟
              # 获取当前图像帧,然后对图像进行二值化处理
              list_line = img.find_lines()
              num = len(list_line)
              if num == 2:
                  if number_model =1 :
                      #left()
                      uart_tx.write('left\n')
                      break
                  elif number_model = 2:
                      #right()
                      uart_tx.write('right\n')
                      break
              # 进行直线检测
              if (line):
                  if line.theta()>90:
                      theta_err = line.theta()-180
                  if line.magnitude()>8:
                      #car.run(50+output, 50-output)
                      #right()
                      if 50+output>50-output:
                          #左快右慢,向右转
                          #right()
                          break
                      elif 50+output<50-output:
                          #left()
                          break
                          #Go()
                          uart_tx.write('Go\n')
                          break
                      #car.run(0,0)# 左右速度为0,停止
                      #stop()
                      uart_tx.write('stop\n')
                      break
                  #car.run(50,-50)#向左转
                  #left()
                  break
                  pass
              #print(clock.fps())
          # 此函数仅用于确保小车沿着红线走
      def numfind(num_model):
          # 跳过一定时间内的图像帧
                  #print(output)
                  #print(max(output))
                  number = output.index(max(output))
                  if number == num_model:
                      if number == 3:
                          #left()
                          break
                      elif number==4:
                          #right()
                          break
                      elif number==5 or number==7:
                          #left()
                              if number ==5:
                                  #right()
                                  break
                              elif number==7:
                                  #left()
                                  break
                      elif number==6 or number==8:
                          #right()
                              if number ==6:
                                  #right()
                                  break
                              elif number==8:
                                  #left()
                                  break
          motor()
          num_model = uart_rx.read(10)
          numfind(num_model)
    • https://singtown.com/learn/50235/
      先单独测试发送串口的代码。
