  • tflite文件找不到怎么办?
    • # This code run in OpenMV4 H7
      sensor.set_pixformat(sensor.GRAYSCALE)    # Set pixel format to RGB565 (or GRAYSCALE)
          img = sensor.snapshot().binary([(0,64)])
          for obj in tf.classify("trained.tflite", img, min_scale=1.0, scale_mul=0.5, x_overlap=0.0, y_overlap=0.0):
              output = obj.output()
              number = output.index(max(output))
              print(number)
          print(clock.fps(), "fps")
    • 如果你使用的是OpenMV4,使用星瞳ai云服务训练。https://ai.singtown.com/
