  • Arena size is too small for all buffers.
    • Arena size is too small for all buffers. Needed 225840 but only 189856 was available. AllocateTensors() failed!
      # Untitled - By: Administrator - 周五 7月 14 2023
      import sensor, image, time, os, tf, math, uos, gc ,ustruct ,pyb
      from pyb import UART ,LED ,Timer
      uart = UART(3,115200)   #定义串口3变量
      sensor.set_framesize(sensor.QQQVGA)
      sensor.set_vflip(True)
      sensor.set_hmirror(True)#水平镜像
      global r_flag
      r_flag = 1
      def outuart(x,a,flag):
          global uart
          f_x=0
          f_a=0
          if flag==1: #十字
              x,a,f_x,f_a=(0,0,0,1)
          if flag==2: #上左
              x,a,f_x,f_a=(0,0,1,0)
          if flag==3: #上右
              x,a,f_x,f_a=(0,0,1,1)
          if flag==4: #stop
              x,a,f_x,f_a=(1,1,1,2)
          data = ustruct.pack("<bbhhhhb",      #格式为俩个字符俩个短整型(2字节)
                         0x2C,                      #帧头1
                         0x12,                      #帧头2
                         int(x), # up sample by 4   #数据1
                         int(a), # up sample by 4    #数据2
                         int(f_x), # up sample by 4    #数据1
                         int(f_a), # up sample by 4    #数据2
                         0x5B)
          if flag!=1:
              uart.write(data)  #必须要传入一个字节数组
                  time.sleep_ms(1)
      def findline():
          global r_flag
          THRESHOLD = (18, 61, 14, 89, -2, 63)
          LED(1).on()
          LED(2).on()
          LED(3).on()
          roi1 = [(0,17,15,25),#左
              (65,17,15,25),#右
              (30,0,20,15)]#上
          left_flag,right_flag,up_flag=(0,0,0)
          for rec in roi1:
                  img.draw_rectangle(rec, color=(255,0,0))#绘制出roi区域
          if (line):
              if line.theta()>90:
                  theta_err = line.theta()-180
              if line.magnitude()>8:#if -40<b_err<40 and -30<t_err<30:
                  outdata=[rho_err,theta_err,0]
                  print(outdata)
                  outuart(rho_err,theta_err,0)
                  if img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[0]):  #left
                      #print('left')
                      left_flag=1
                  if img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[1]):  #right
                      #print('right')
                      right_flag=1
                  if img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[2]):  #up
                      #print('up')
                      up_flag=1
                  if left_flag==1 and right_flag==1:
                      outuart(0,0,1)
                      #time.sleep_ms(5)
                      print('shizi')
                  if left_flag==1 and up_flag==1:
                      outuart(0,0,2)
                      print('up-left')
                  if right_flag==1 and up_flag==1:
                      outuart(0,0,3)
                      print('up-right')
              outuart(0,0,4)
              print('stop')
      global x,y,target,t_flag,middle_x
      middle_x = 120
      flag=0
      target = 0
      t_flag = 0
      def FirstFindNum(Finded_Num):
          global target,t_flag,uart
          if t_flag == 0 and Finded_Num>0:
             target = Finded_Num
             t_flag = 1
             print('+++++++++++++++++++++++++已经识别到数字+++++++++++++++++++++++++++++++++++')
             data = ustruct.pack("<bbhb",      #格式为俩个字符俩个短整型(2字节)
                         0x2C,                      #帧头1
                         0x12,                      #帧头2
                         int(t_flag), # up sample by 4   #数据1识别到目标的标识符
                         0x5B)
             uart.write(data)
             return target
      global s_flag
      s_flag = 0
      def FindNum(x,y,target,i):
          global s_flag,flag,uart,t_flag,x_flag
          if t_flag == 1 and target == i:
              s_flag+=1
              x_flag = 0
              if(s_flag == 20):
               print('//////////////////////////////发送一次标志位////////////////////////////////////////')
               s_flag = 0
               x_flag = 1
              if x>middle_x:
               flag=1
               print(flag)
               flag=0
               print(flag)
              if x_flag>0:
               data = ustruct.pack("<bbhhb",      #格式为俩个字符俩个短整型(2字节)
                         0x2C,                      #帧头1
                         0x12,                      #帧头2
                         int(x_flag), # up sample by 4   #数据1识别到目标的标识符
                         int(flag), # up sample by 4    #数据2左右标识符 -1 是左 1是右
                         0x5B)
      def findnum():
          net = None
          labels = None
          min_confidence = 0.7
              (255,   0,   0),
              (  0, 255,   0),
              (255, 255,   0),
              (  0,   0, 255),
              (255,   0, 255),
              (  0, 255, 255),
              (100, 255, 255),
              (255, 100, 255),
              (255, 255, 100),
              (255, 255, 255),
          #try:
          net = tf.load("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (128*1024)))
          #except Exception as e:
              #raise Exception('Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')
          #try:
              #raise Exception('Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')
          # of our objects
          data = net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
          for i, detection_list in enumerate(data):
              for d in detection_list:
                  global center_x,center_y
                  if i==1:
                          print('数字1',d.output())
                          [x, y, w, h] = d.rect()
                          #img.draw_cross((center_x, center_y), color=colors[i], size = 10, thickness=2)
                          img.draw_string(center_x + 12, center_y + 12, labels[i], color=colors[i],scale=4)
                          img.draw_rectangle(x-35,y-50, w+70, h+90, color =colors[i], thickness = 1, fill = False)
                          #outuart(center_x,center_y,i)
                          FirstFindNum(i)
                          FindNum(center_x,center_y,target,i)
                  if i==2:
                          print('数字2',d.output())
                          FirstFindNum(i)
                  if i==3:
                          print('数字3',d.output())
                          FirstFindNum(i)
                  if i==4:
                          print('数字4',d.output())
                          FirstFindNum(i)
                  if i==5:
                          print('数字5',d.output())
                          FirstFindNum(i)
                  if i==6:
                          print('数字6',d.output())
                          FirstFindNum(i)
                  if i==7:
                          print('数字7',d.output())
                          FirstFindNum(i)
                  if i==8:
                          print('数字8',d.output())
                          FirstFindNum(i)
          print(r_flag)
          global r_flag
          if uart.any():
           a = uart.read(1).decode().strip() #uart.read()为一个字节串,加.decode() 变成字符串
           r_flag = int(a)
           print(r_flag)
          if r_flag == 0:
           findline()
          elif r_flag == 1:
           findnum()
    • 这个报错是因为什么问题
    • openmv h7 plus
    • 先精简为直接运行就报错的代码。你的代码我没办法测试。
