  • Failed to load"trained.tflite"did you copy t
    • 0_168907231ng
      我遇到这个问题,好多方法都是了都不行,重新上电都不行,用官方代码也不行
      Edge Impulse - OpenMV Object Detection Example
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
      (255, 0, 0),
      ( 0, 255, 0),
      (255, 255, 0),
      ( 0, 0, 255),
      (255, 0, 255),
      ( 0, 255, 255),
      (255, 255, 255),
      # of our objects
          for d in detection_list:
              [x, y, w, h] = d.rect()
    • 估计你使用的是OpenMV4 H7。
      最简单的办法是用星瞳AI在线服务生成模型。https://docs.singtown.com/ai/zh/latest/toturial/classify.html
