  • 连接上wifi扩展板之后运行程序,其他设备识别不到OPENMV_AP热点是什么原因
    • # MJPEG Streaming AP.
      # This example shows off how to do MJPEG streaming in AccessPoint mode.
      # Chrome, Firefox and MJpegViewer App on Android have been tested.
      # Connect to OPENMV_AP and use this URL: http://192.168.1.1:8080 to view the stream.
      # Reset sensor
      # Init wlan module in AP mode.
      print("AP mode started. SSID: {} IP: {}".format(SSID, wlan.ifconfig()[0]))
      # You can block waiting for client to connect
      def start_streaming(s):
          client, addr = s.accept()
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          # Start streaming images
              frame = sensor.snapshot()
              header = "\r\n--openmv\r\n" \
              client.send(header)
              client.send(cframe)
          # Create server socket
              # Bind and listen
              s.bind([HOST, PORT])
              s.listen(5)
              # Set server socket timeout
              s.settimeout(3)
              start_streaming(s)
          except OSError as e:
              s.close()
              print("socket error: ", e)
              #sys.print_exception(e)
    • 使用的就是官方给的例程,没做改动
    • 手机,电脑,都扫描不到这个WiFi热点吗?
    • @kidswong999 是的
    • 检查一下插针有没有焊接好,如果没问题,可以联系售后寄回检查。
    • @kidswong999 好的
