  • 如何修改下列代码将openmv数据传输到arduino板上再控制小车循迹运动?
      THRESHOLD = (35, 9, -24, 32, -20, 7) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      #sensor.set_vflip(True)
      #sensor.set_hmirror(True)
      clock = time.clock() # to process a frame sometimes.
      if (line):
      if line.theta()>90:
      theta_err = line.theta()-180
      if line.magnitude()>8:
      car.run(50+output, 50-output)
      car.run(0,0)
      car.run(50,-50)
      pass
      #print(clock.fps())
    • https://singtown.com/learn/50235/
      参考这个视频,代码要自己改。
