  • 在Edge impluse上训练的模型显示报错
      sensor.set_windowing((240, 230))       # Set 240x240 window.
      net = None
      labels = None
      except Exception as e:
          print(e)
          for obj in net.classify(img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):#显示该行错误
          print(clock.fps(), "fps")
    • 看上去是模型设置的不对。要用mobilenet。
