  • openmv跑神经网络报错快帧缓冲区堆栈内存满了,要调低分辨率跳过错误
      sensor.set_framesize(sensor.QQQQVGA)      # Set frame size to QVGA (320x240)
      net = None
      labels = None
      except Exception as e:
          print(e)
          print(clock.fps(), "fps")
    • 如果你使用的是OpenMV4 H7, 用星瞳ai云服务训练小模型:https://ai.singtown.com/
