  • 为什么 每次录制视频的时间都会少呢?哪位大佬帮忙看看 设置的是录制15个小时 出来每段视频只有20分钟 共30段视频
    • import sensor, image, time, mjpeg, pyb
      from pyb import RTC
      RED_LED_PIN = 1
      BLUE_LED_PIN = 3
      Time = [2023, 6, 4, 7, 0, 1, 0, 0]
      Act_Time = [4, 7 , 0 , 0]
      Set_Time = [0, 15, 0, 0]
      Days = 2
      X = 30
      Fps = 44
      rtc = RTC()
      rtc.datetime(Time)
      m = [0]
      for B in range(X * Days):
          m.append(mjpeg.Mjpeg(str(B + 1) + ".mjpeg"))
      for Day_count in range(Days):
          pyb.LED(RED_LED_PIN).on()
          print("You're on camera!")
          while((rtc.datetime()[2] * 86400 + rtc.datetime()[4] * 3600 + rtc.datetime()[5] * 60 + rtc.datetime()[6]) < ((Act_Time[0] + Day_count) * 86400 + Act_Time[1] * 3600 + Act_Time[2] * 60 + Act_Time[3])):
              print("**********Wait**********" + '\n')
              print(str(rtc.datetime()[4]) + 'h', str(rtc.datetime()[5]) + 'm', str(rtc.datetime()[6]) + 's')
              print("wait" + '\n')
          pyb.LED(RED_LED_PIN).off()
          pyb.LED(BLUE_LED_PIN).on()
          for A in range(X):
              for i in range(Fps * ((Set_Time[0] * 86400 + Set_Time[1] * 3600 + Set_Time[2] * 60 + Set_Time[3]) / X)):
                  print("**********ACT**********" + '\n')
                  m[A + 1 + X * Day_count].add_frame(sensor.snapshot())
                  print(str(clock.fps()) + 'fps' +'\n', "Num = " + str(i))
                  print(A + 1 + X * Day_count, '\n' )
              m[A + 1 + X * Day_count].close(clock.fps())
          pyb.LED(BLUE_LED_PIN).off()
          print("Done! Reset the camera to see the saved recording.", '\n')
    • 你这个rtc我看着不知道什么意思,如果要录制15小时, 可以用millis()判断.
      RED_LED_PIN = 1
      BLUE_LED_PIN = 3
      sensor.skip_frames(time = 2000) # Give the user time to get ready.
      start = pyb.millis()
      while (pyb.millis()-start) < 15*60*60*1000:
      m.close(clock.fps())
      print("Done! Reset the camera to see the saved recording.")
