  • find_circles 函数 ,如何在历程中设置感光区域,上传电脑观看?
    • 我在find_circles 函数中设置了roi区域,但是上传到电脑上的图像并没有改变,如何改变电脑上的图像区域?
      ROI=(13,0,120,120)
      sensor.set_pixformat(sensor.GRAYSCALE) # grayscale is faster
      sensor.set_windowing(ROI)
      led = pyb.LED(1)
          led.on()
          # Circle objects have four values: x, y, r (radius), and magnitude. The
          # magnitude is the strength of the detection of the circle. Higher is
          # better...
          # `threshold` controls how many circles are found. Increase its value
          # to decrease the number of circles detected...
          # `x_margin`, `y_margin`, and `r_margin` control the merging of similar
          # circles in the x, y, and r (radius) directions.
          # r_min, r_max, and r_step control what radiuses of circles are tested.
          # Shrinking the number of tested circle radiuses yields a big performance boost.
          for c in img.find_circles(roi=ROI,threshold = 1200, x_margin = 10, y_margin = 10, r_margin = 10,
                  r_min = 1, r_max = 5, r_step = 2):
             #img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))
             print(c)
         #print("FPS %f" % clock.fps())
    • @quy4 sensor.set_windowing(ROI) 这个函数设置的区域最大值好小好小,不能满足需求,
    • 如果你是用QQVGA,那么ROI是可以覆盖整个画面。不存在“最大值好小好小,不能满足需求”
    • 另外如果设置了sensor.set_windowing(ROI)
      那么find_circles里面就可以不用roi参数。
