  • 还是刚才的问题,为什么我拍照成功后,用32的板子的为openmv提供5v电源,结果就闪了一下白灯,按按键发送无法拍照?
    • 我把32板子和openmv都连在电脑上,串口也连接了,按按键可以发送OK,复位后也可以拍照,但是用32来为openmv供电却无法拍照。
      # UART Control
      # This example shows how to use the serial port on your OpenMV Cam. Attach pin
      # P4 to the serial input of a serial LCD screen to see "Hello World!" printed
      # on the serial LCD display.
      import sensor, image, pyb
      RED_LED_PIN = 1
      BLUE_LED_PIN = 3
      sensor.set_framesize(sensor.QVGA) # or sensor.QQVGA (or others)
      pyb.LED(RED_LED_PIN).off()
      pyb.LED(BLUE_LED_PIN).on()
      print("You're on camera!")
      # Always pass UART 3 for the UART number for your OpenMV Cam.
      # The second argument is the UART baud rate. For a more advanced UART control
      # example see the BLE-Shield driver.
      uart = UART(3, 9600, timeout_char=1000)
          if uart.any():
              a = uart.readline().decode()
              print(a)
              if a == "OK\r\n":
                  img.morph(1, [+2, +1, +0,\
                                +1, +1, -1,\
                                +0, -1, -2]) # Emboss the image.
                  img.save("example.jpg") # or "example.bmp" (or others)
                  pyb.LED(BLUE_LED_PIN).off()
                  print("Done! Reset the camera to see the saved image.")
      想问一下为什么用32为openmv提供5v电源无法拍照并储存到SD卡,以及如何实现不复位按一下按键就拍一张照。
    • OpenMV的VIN引脚5v供电。
      OpenMV 运行了脱机运行的步骤。
      串口连线正确,是否有共地。
    • 请说准确的现象,什么叫做无法拍照?
